When creating an ordered list, the numbering works as expected initially. However, if I add a new ordered list item after a line break (without any separator), the numbering doesn’t reset and instead continues from the previous list. For example, typing 1.
after a previous ordered list results in it being rendered as 4.
instead of 1.
. This only happens when there’s no content (like a horizontal rule or text) separating the lists. If a separator is present, the numbering resets correctly.
Steps to Reproduce:
Create an ordered list, such as:
1. 111 2. 222 3. 333
Add a line break to make the content look like this:
1. 111 2. 222 3. 333 <cursor here>
At the cursor position, type
1.
to start a new ordered list item.- Observed Behavior: It renders as
4.
(continuing the previous list). - Expected Behavior: It should render as
1.
(starting a new list).
Now, try this scenario with a separator:
1. 111 2. 222 3. 333 --- or anything else <cursor here>
1.
.- Observed Behavior: It correctly renders as
1.
(new list starts).
It seems like Bear treats the new list as a continuation of the previous one unless explicitly separated. Is this intended behavior, or is there a setting I can adjust to reset the numbering automatically after a line break? Any help would be appreciated!
