specifically on ipad and ios
On iPad you can have two separate instances of Bear side by side with the iPadOS built in split screen function.
You can have same note or different notes side by side and can edit on both sides.
But this is currently not possible on iPhone.
PS. Not all iPad models support split screen. Split screen is available on the following iPad models: iPad Pro, iPad Air 2 and later, iPad 5th generation and later, and iPad mini 4 and later.
Did not realize my iPad could do this! THANK YOU
