In the current version of the Panda (Version 1.0 (3148)), should I expect wiki links to actually work? I seem to be able to create wiki links, but they don’t seem to actually work. FWIW – I’m attempting to use wiki link syntax to point at a different .md file in the same directory.
No, this version of Panda does not support wikilinks or tags. You can, however, use a direct file link, e.g. file:///Users/... as the url. That’s obviously not ideal but it gets you part of the way there.
The team is working on an updated version of Panda that will presumably support wikilinks, tags, and more: https://community.bear.app/t/panda-sneak-peek-a-work-in-progress-markdown-editor-and-library
