Bear Version: 2.6.6 (latest version as of 1/28/2026)
OS Version: Windows 11
What were you doing: clicking on entries in the sidebar
What feature did you use: I had just entered a new file in one subject. Then I changed to another subject in the sidebar.
What happened: The cloud icon on top of the screen flashed, the new subject appeared and the new entry in the subject I had previously selected, disappeared.
What did you expect to happen: I expected the new entry to be sent to the cloud and to remain in the Windows 11 version of Bear even when I change subjects in the sidebar.
Note: I may not be using the correct terminology for parts of Bear, sorry.
Yes, that is correct. As of this morning (1/29/2026) nothing that I write is saving. Regardless of whether I am just altering an existing entry or starting a new one.
thanks for the update. I’m going to add some public diagnostic tools in the next update (likely on Monday), I’ll ask you to run one of them if you’re comfortable with that.
@pregan we added a diagnostic function available in the dev console to expose the sync status.
To use it, open the dev console (cmd-shift-I on mac, ctrl-shift-I on win), and type iCloudSyncStats() in the console (followed by enter).
You should see a structure like the following (likely populated with different values):
Same goes for @Stella of course, if you feel like sending over the sync stats (see comment above) in case you encounter the issue again, it would be amazing!
