Side Panel Sizing
Operation system: Windows 10
Web Browser: MS Edge
What were you doing: Fitting to a different monitor
What feature did you use: Tried to adjust width of side panels
What happened: nothing
What did you expect to happen: I thought I would get a cursor change and be able to drag the width.
First, thanks SO much for Bear web. It has changed my use of Bear, and made it available at work. I can just use Bear whenever needed, and no frustration. So cool!
It would be nice if the width of side panels could be adjusted, for times when there is less monitor space available.
Hi and thanks for the feedback! I confirm that currently panel sizes cannot be adjusted. This may come in a future release, but in the meantime you can still switch to a different layout (1, 2 or 3 columns) using shortcuts
That will work fine for now, thanks for the response.
