Testing version: 2.0.2 (Now GA)
What were you doing:Upgrading from 1.latest to 2…latest
What feature did you use: Nested Tagging (main reason I moved to Bear)
What happened: Just upgraded to Bear 2.0.2 and noticed that tags based on using special characters [ and ], i.e. square brackets worked fine in 1.X but don’t in v2.X. e.g. #work/sub-tag-name/[review]/sub-sub-tag-name/# now splits the tag into 2.
What did you expect to happen: For all working nested tags in 1.x to work under 2.x. I know you should avoid special characters where possible, but UX should prevent if not valid. Please advise is this is planned to be fixed or how I can search and replace hundreds of notes (Find & Replace appears to be limited to a single Note) with a new tag name as uts built into my nested tagging hierarchy. I have support engaged, but though id share with community.
